Linear Array; Skip Instance
Irich
Irich
Two fold question here.
1) Is there a way to 'skip instance' in an array?
2) If I have an array that is already established; is there a way to go back and skip an instance?
My end goal is this: if I have an array with 7 instances and I want to move the 3rd instance over 2" without effecting the other 6 instances. How would I do that?
The only way that I have found is by deleting the 3rd instance but then I have effectively eliminated my array and end up with 7 individual components.
Thanks!
L.Maas
No, is (unfortunately) not possible in Revit. Also using a visibility parameter does not work as the array is a copy of an instance.
Have a look in the IDEAS FORUM, see if something similar is presented, if not add your won idea.
Louis
Please mention Revit version, especially when uploading Revit files.
Irich
Thanks Louis!
A_MAQ
you may can make the array parameteric
try that
Autodesk Expert Elite
