Announcements
Line hierarchy in wireframe view
emilys27ZKX
emilys27ZKX
I've been having an issue with the lines from the wall below overriding the walls above in our plan views. The gray walls are at the cut level (walls below) and the dashed lines are the walls above. These are set up using filters in a view template. Our visual style is set to wireframe so that we can see through multiple levels without having to control the transparency of multiple elements and so we can see the poche on the walls below. The issue at hand is that the boundary line of walls below seem to be overriding the boundary of the walls above, but only in certain areas. I'm at a loss as to why this is happening. In the example screenshot below, the walls are split from level to level, do not overlap, they have the have the same top and bottom offsets, same base levels, same worksets, same structural usage. If anyone has and ideas on how to fix this I would be forever grateful.Line hierarchy.JPG
jay_colcombe
It is difficult to fully appreciate what is going on but I know Structural Plans are very particular as regards representation of elements etc and some background rules are in place so would suggest redwing the Hidden Line options in the Views Properties as this often has been highlighted as a cause in visibility issues?
Also are the walls the same Type/Position/Stacked as the Horizontal one appears to have a double dash?
Jay Colcombe
Autodesk Certified Instructor
