Line Break in Text
Line Break in Text
Message 1 of 10
Line Break in Text
I have a title block with a tag for the sheet name. I know that the text will automatically wrap, but I'd like to force a line break at a point prior to when it would automatically wrap. In Excel you can press to accomplish this. Is there any equivalent in Revit Structure?
Replies (9)
Message 2 of 10
jhudtwalcker
Hi Stephen
did you solve this problem? if not, here's the solution: you have to pres CRTL+ENTER, but not in the drawing area, but in the properties field... Hope it works
Message 3 of 10
MostafaElashmawy
Use shift+Enter to do the line break.
Mostafa Elashmawy
Message 4 of 10
GallowayUS_com_RonAllen2
Dang it !:
Revit 2018:
Name cannot contain any of the following characters:
or any of the non-printable characters.
Ron Allen
Galloway BIM
Message 5 of 10
Ah- I see in the //**VIEW TITLE ONLY**//in the properties... then it allows ctrl+enter for a force break (Line feed in ASCII(10?)??).
Ron Allen
Galloway BIM
Message 6 of 10
Topspap.1994
it did work, Thanks
Message 7 of 10
mohammad.faraji
Community Visitor
Community Visitor
Hi, How did you solve this problem? I received the same error.
Message 8 of 10
CTRL+Enter for a force-break on multiline text.
Ron Allen
Galloway BIM
Message 9 of 10
dsylvesterWB8T3
Community Visitor
Community Visitor
Hello, do you know if this is still true?
When I try ctrl+enter or shift+enter I get an error saying:
"Name cannot contain any of the following characters:
or any of the non-printable characters."
I'm using Revit 2021.
Message 10 of 10
SCygielski
Looks like Autodesk "fixed" this workaround in typical Autodesk fashion.
