Joining two different floors
Hello everyone,
I am currently trying to join two different floors as you can see throutgh the picture that I uploaded. the problem is that the command aint working.
Luiscko
For the floor with floor it does not working, if you want to join i recomend you copy your skech and the you edit and copy the sketch in the other, i think this is the faster way to join existing floors
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
