join geometry revit
join geometry revit
join geometry revit
When we model a structural slab and beam in Revit, it automatically get joined. I noticed that by default beam volume get reduced. But structurally we need the beam volume should retain same and slab volume should reduce. how fix this. please refer the attached snaps we need as clouded in section A. is
A_MAQ
Hi @Anonymous,
you can switch join , so the beam volume will remain as it is.
Autodesk Expert Elite
 DEAR @thankachans,
There is not default settings to change SWITCH JOIN ORDER for BEAM.
you have to do manually every time to change switch join order for BEAM.
or you can use Dynamo to switch all beam join with one click.
i am not expert in dynamo but you can check https://forum.dynamobim.com for more information.
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
