iTwin Services
iTwin Services
NAtovski
Observer Observer
iTwin Services
NAtovski
Observer
Observer
I'm using Revit 2022 and I've seen some of my coworkers show me a "bentley" tab on the main ribbon. In that tab you are able to use iTwin Services and export the revit structural model. I'm trying to export the model from Revit 2022 and import it to STAAD.Pro Physical Modeller. Not sure if theres an option on Revit I am not selecting or if I need to use some workaround method.
In STAAD.Pro I see the iTwin Services tab but for some reason that isnt showing up in Revit.
jay_colc
This would be a Third Party Addin for Revit.  You would need to go to the Bentley or STAAD website and download and install this into Revit and will appear on the Ribbon.
ISM Revit Plug-in | Bentley Systems | Infrastructure Engineering Software Company
The only other explanation would be if you are using Revit LT which does not support Addins!
Jay Colcombe
Autodesk Certified Instructor
