Issues with revit 2019 connections
jarendon4F49D
jarendon4F49D
I have 3 WT members connected to an HSS column with a gusset plate connection. The connection family I’m using is called “Gusset plate for 3 diagonals”.
Everything was working well until I started spacing out my bolts from center of my beams/braces and they came off  completely! I'm trying to connect the WT flange with the plate but I can't find a way to do that.
Any idea of what I can do?
Below are some screenshots of the issue:
Ahmed_Muharram
check this thread it might help
https://forums.autodesk.com/t5/revit-structure-forum/how-do-you-place-a-purlin-connection-angle-on-b...
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
jarendon4F49D
I still don't understand what is going on with the Revit out-of-the-box connection, but the tread did show me how to make my own custom connection which I think is what wants to happen here.
Thanks for the help!
