integrate an existing 3D environment on REVIT
As part of a graduation project, I am looking for how to integrate an existing 3D environment on REVIT (to work then on the 3D site installation plans). I used the site "cad mapper" which allows to export in .dxf format or sketchup the complete topography of a zone.
I have tried several things, either go autocad to output a dwg format (in this case , on REVIT,  elements are not exploitable), or go through sketchup to export an ifc file (in this case, the roads disappear or are not exploitable)
Would you have a solution to get on revit a clean environment but especially fully exploitable with the relief, the roads and the buildings to modify the textures etc ..
Thank you
Victoria
shefypattambi
Hi @Anonymous ,
Did you try to import the skp file from "Insert - import cad " and file type skp ?
I have tried but it does not work....
When I try to import it or  bind it, a message tell me that the file can not be open and is not found...
shefypattambi
Hi @Anonymous ,
Could you please upload your skp file ?
It is not working
Do you have an email?
shefypattambi
Hi @Anonymous,
I have PM you.
shefypattambi
I am sorry. Me too facing the same issue.
But it is opened in Tekla Like this.
