Hello, I have a problem with giving image to varying rebar set in schedule. It is not active. Other bars is ok but in varying bars there is not button to add image. I am using Revit 2019. You can have a look at the attached picture.
Solved by ovidiu_paunescu. Go to Solution.
Hello @Anonymous
It looks like you are using the image assigned per rebar instance. This is currently not possible for bars in a varying rebar set.
What you can do is set an image for the rebar shape with A, B, C parameters. You can also show the length as varying between a minimum and a maximum value
The shape image can be added to the shape family
And the parameter set as "calculate min and max" from the formatting tab in the schedule
I've attached a sample file showing this example
