IFC model misplaced after inserting
shuaib009
shuaib009
Hi All,
I have a steel model in IFC format, tried to link to Revit precast structure model.
But, after linking to Revit model, Steel model is not in proper place (as shown in attached image).
Kindly guide if any of you gone through this problem. (I have used Internal Origin to Internal Origin while linking IFC)
Regards.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
Try
- export Revit model to IFC with the same origin
- link both IFC in Solibri to check if the coordinates are the same
Rafal Gaweda
shuaib009
How we can find out the origin of any model?
I think I can use navisworks manage instead of solibri?
ennujozlagam
you need to have shared coordinates ? sample here. thanks
