ifc in rvt in uncorrect coordinates (0,0)
ihtornWRV8J
ihtornWRV8J
I have some  dwg and ifc files, which i sucsesfully  gathered in navisworks. But when i put it in rvt, only dwg i see in right place, all ifc lies near 0,0. When i put in rvt coordination model nwc whith the same ifc, it lies in another place far from dwg and ifc. Whats the matter?
jay_colcombe
It would suggest to me the Revit model has some other coordinate system, can you turn on in the Revit model via Visibility Graphics > Site > Internal Origin + Project Base Point + Survey Point are they on top of each other?
Jay Colcombe
Autodesk Certified Instructor
ihtornWRV8J
They all in equal point.
jay_colcombe
Am to assume if you selected the Project Base Point and the Survey Point they would read 0,0,0?
If this is the case it would indicate the Revit model has no shared coordinates setup and the other models may have.
In Navisworks you could simply move the Revit model using the Transform Tool into the correct place but i am unsure what you are trying to achieve overall?
All in the Correct Place in Navisworks?
All in the correct Place in Revit?
Jay Colcombe
