when exporting the model to IFC ( IFC2x3 coordination view 2.0) and option " include steel elements" ticked in the IFC model the:
structural columns
Structural connections
When " include steel elements" ticket off the columns apear in the IFC model okay, but connections are not exported
is there a way to correctly export all steel components to IFC ?
thank you for your input in advance
"When you export a Revit building information model to IFC format, the information can be used directly by other building specialists, such as structural and building services engineers. "
Hello
The option "include steel elements " create a bug with steel position in model.
Seems to be with the fabrication shape functionality.
You can search on the GITHUB page of IFC exporter to add a ticket.
Only possibilty is to export as DWG to get the full LOD.
And personaly i've already posted some threads about problems with IFC export & steel, To say it's the only way.
Sorry.
Thank you for the quick reply ; Didnt find an answer to my problem so i posted this one ;
Bummer !
there are more ifc export issues with steel you wrote !? Where can i find info about that ?
at least i wil report this issue at
https://github.com/Autodesk/revit-ifc/issues
Regards
Hi, you can check at this thread.
or simply search for IFC in this forum.
Hi @Anonymous ,
Are the issues reproducing on the Revit default Export to IFC feature?
To do this:
1. Uninstall the IFC Exporter. (you can install it back, after the testing)
2. Open the Revit project, export an IFC file (File->Export->IFC) and open it in Solibri, or another IFC viewer.
Are the issues that you mentioned reproducing?
