Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
IFC export option include steel elements messing up columns and connections
4 REPLIES 4
2682 Views, 4 Replies
when exporting the model to  IFC ( IFC2x3 coordination view 2.0) and option " include steel elements" ticked in the IFC model the:
structural columns
  • appear in wireframe
  • base level and offset is wrong (see attachment)
  • missing profile name etc
Structural connections
When " include steel elements"  ticket off the columns apear in the IFC model okay, but connections are not exported
is there a way to correctly export all steel components to IFC ?
thank you for your input in advance
  • REVIT 2020.2
  • IFC exporter for REVIT 2020 (downloaded last week)
"When you export a Revit building information model to IFC format, the information can be used directly by other building specialists, such as structural and building services engineers. "
About Revit and IFC
4 REPLIES 4
AntDrt
Hello
The option "include steel elements " create a bug with steel position in model.
Seems to be with the fabrication shape functionality.
You can search on the GITHUB page of IFC exporter to add a ticket.
Only possibilty is to export as DWG to get the full LOD.
And personaly i've already posted some threads about problems with IFC export & steel, To say it's the only way.
Sorry.
Antoine
AMG Fechoz
Serrurerie & Equipement Scénographique
www.amg-fechoz.com
in reply to: AntDrt
Thank you for the quick reply ; Didnt find an answer to my problem so i posted this one ;
Bummer !
there are more ifc export issues with steel you wrote !? Where can i find info about that ?
at least i wil report this issue at
https://github.com/Autodesk/revit-ifc/issues
Regards
AntDrt
Hi, you can check at this thread.
https://forums.autodesk.com/t5/revit-structure-forum/export-ifc-steel-element-bug-still-here-revit-2....
or simply search for IFC in this forum.
Antoine
AMG Fechoz
www.amg-fechoz.com
mihai.sandu
Hi @Anonymous ,
Are the issues reproducing on the Revit default Export to IFC feature?
To do this:
1. Uninstall the IFC Exporter. (you can install it back, after the testing)
2. Open the Revit project, export an IFC file (File->Export->IFC) and open it in Solibri, or another IFC viewer.
Are the issues that you mentioned reproducing?
Mihai Sandu
Sr. QA Analyst
Forma Design Contest
