Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
I would like to create a customizable rebar tag that shows triangles on the bar which symbolize the layer in which the rebar is situated.
2 REPLIES 2
181 Views, 2 Replies
In the upper picture, you can see the rebar tag with the triangles i would like to make customizable. They need to be customizable per instance.
Here are the parameters i have set up, boven means top layer. Right now the parameter is set to instance, but the checkboxes won't show up in my properties panel as seen in the first image. When i use a type parameter, the family becomes linked so i have to create a new family type per rebar set. I would prefer if it could be one type. Does anyone know a solution.
Ps. the triangles are 4 detail items, 1 of those only has one triangle, one has 2 etc. they are layered on top of each other.
Labels (6)
2 REPLIES 2
Tom_Kunsman
in reply to: 1031419
You should look into Shared Parameters in Revit. They are the only way of adding info to a tag. https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-E7D12B71-C50D-46D8-886B-8E0C2B285988
in reply to: Tom_Kunsman
Thank you, i'll have a look
Forma Design Contest
