Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
I need your help to model this pier....
3 REPLIES 3
diyarvb
245 Views, 3 Replies
Hi
I need your help to model this pier in revit 2022
and recording modeling procedure "if you can"
thanks
3 REPLIES 3
Hi, what do you think about this? I can adjust the family if you need to. How are you planning to model the deck?
Steps for creating the family:
1) I've recreated the polyline for the sections A-A and B-B in AutoCAD. (They weren't straight)
2) Create two Metric Profile families: insert dwg, explode, purge. Load them into the family under 3)
3) Create  a Generic Model two level based
4) For the main bottom part: Sweep. Main top part: Swept blend. Bearings: Extrusions. I haven't added any parameters to the width/depth of the bearings. I have changed the type to a structural column.
5) Add the family to a project. You can adjust the height of the main bottom part and also the bearing blocks.
diyarvb
in reply to: diyarvb
Thank you very much
Accept the solution if you are satisfied
