hydraulic structures
Hi friends, I work with hydraulic structures, and curves that are defined by equations, is there any way I can draw those curves in the revit providing the equation? Or import a points table for revit to draw?
KrisAribal
You can create those curves as a family. In the family editor, you have the option to create those curves which follows the said equations
martinTstewart_Adsk
Autodesk Support
Autodesk Support
You may also want to check out this Linkedin Learning course: Revit: Parametric Curvature in the Family Editor
Martin Stewart
AEC Support Specialist
