How to vertically rotate steel structure
mnBNLP9
Observer Observer
mnBNLP9
Observer
Observer
I'm modeling the steel structure of a curved staircase, and I would like to rotate a portion of it (between landings) vertically, while keeping all elements unchanged— no automatic adjustments to length or connections.
I've tried grouping the elements and also using linked Revit models, but I couldn't make it work.
Does anyone have any suggestions?
Thanks in advance!
jay_colcombe
It will depend on if it is constrained to levels etc.  you should to be able to rotate in an Elevation/Section as long as the workplane is set to this view?
Have you trued Mirroring instead then just moving it down or assigning an offset to the level?
Jay Colcombe
Autodesk Certified Instructor
_Vijay
How about slanted column?
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
mari.shimode
Hi @mnBNLP9, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still need help from the community, please let us know. Thank you.
Mari Shimode
