How to Share Cloud Based Structural Analysis
ouspensky
Message 1 of 8
ouspensky
Hi again,
I am still trying to learn how to use all the structural analysis tools in Revit.  I just built a concept model of my building and sent it to cloud structural analysis and it failed.  Is there a way to post a link and share my cloud-based analysis so that someone else can open it and see what went wrong?
Replies (7)
Message 2 of 8
teodorb
Hi @ouspensky,
Could you please attach the model you are trying to analyze?
Kind regards,
Bogdan Teodorescu
Product Owner
Message 3 of 8
MostafaElashmawy
You can click on sharing and add an email for some one to have access to the results or download the pdf rep[ort
Mostafa Elashmawy
Message 4 of 8
ouspensky
Please send me your email address by Private Message so I can share my model with you from Autodesk360 Structural Analysis
Message 5 of 8
ouspensky
Hi I read the PM,
1) it was my intention that the braces were braced by the shear walls.
2) I uploaded the model
Message 6 of 8
ouspensky
This post is related. I used a custom material in the model which failed analysis, please have a look: https://forums.autodesk.com/t5/revit-structure-forum/glulam-material-physical-asset-parameters-expla...
Message 7 of 8
teodorb
Hi @ouspensky,
When I firstly try to open the analytical model settings I get this warning:
After closing this warning, you can go in the Analyze tab, Analytical Model Panel and press the arrow from photo below:
Check the following options:
Go to Mange Tab, Inquire Panel and press Warnings. You will see that a lot of warnings (more that 4000) come from the analytical model:
Kind regards,
Bogdan Teodorescu
Product Owner
Message 8 of 8
ouspensky
I followed these directions and now there are no errors during checking and the model still fails in cloud analysis.  I send the you the link and I uploaded the updated model
https://structuralanalysis.360.autodesk.com/Project/2b337a498ada47318f08b2084a151e76?model_id=57661a...
