Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to set the rebar View Visibility States within the View Template for a 3D view?
5 REPLIES 5
spahlevan
1042 Views, 5 Replies
Dear friends, I would like to know if is possible to set the rebar View Visibility States within the View Template.
My objective is to use the filters to show rebars in color (in 3D view). For that I need to have the rebars to be set as "View as solid" from the "View Visibility States", to do so I need to select the rebars and make the view as solid!!
Looking forward to your replies.
Cheers
5 REPLIES 5
Hi @spahlevan ,
That's not possible. View as solid is a parameter of the rebar and not the view.
You can wait till you make all your views then select all rebars and then mark view as solid in all views.
Mostafa Elashmawy
Thanks @MostafaElashmawy  for the reply!!
PavelAnd
in reply to: spahlevan
Hi @spahlevan . That dyn file make rebars solid in all 3d views in project. But you need to restart it after creating new rebars.
Best regards, Pavel Plotitsyn.
spahlevan
in reply to: PavelAnd
@PavelAnd Thank you very much!!
spahlevan
Hello everyone, is it still impossible to control this visibility within "view template" in Revit 2023?
