How to rotate an existing scope box align with near by element?
khalid.ansari7A9T6
Message 1 of 29
khalid.ansari7A9T6
I couldn't find a way to rotate the Existing scope box align with nearby element.
Image attached for your reference.
Replies (28)
Message 2 of 29
vitorbortoncello
Scope boxes don't align
Find the angle value and rotate the scope box
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Message 3 of 29
khalid.ansari7A9T6
Unfortunately, we cannot measure angle of the existing scope box. As Angular dimension command cannot pick scope box boundary.
Message 4 of 29
vitorbortoncello
Maybe I didn't express myself clearly. I meant for you to measure the angle from the axis, draw the scope box straight at 90 degrees, and then rotate it using the angle reference from the axis.
Message 5 of 29
khalid.ansari7A9T6
Thanks @vitorbortoncello  for your quick response.
Your answer is correct if we want to align creating a new scope box.
But my question is regarding the existing scope box in the project. and that existing scope box is already in a particular angle and we want to rotate and align with near element, Hope my it is clear now.
Please let me know if there is any solution
Thank you
Message 6 of 29
jay_colcombe
I may be repeating or missing a step but I simply select the Scope Box and use the Rotate Tool, this allows me to position the node exactly on the element I wish to align against, set the angle as Horizontal and roate ontpo anoth element node and the Scope Box orients accordingly.
Jay Colcombe
Autodesk Certified Instructor
Message 7 of 29
khalid.ansari7A9T6
Hi @jay_colcombe
But my question is regarding the existing scope box in the project. and that existing scope box is already in a particular angle and we want to rotate and align with near by element,
Message 8 of 29
khalid.ansari7A9T6
Message 9 of 29
jay_colcombe
I appreciate the dilemma now so unless you drop the node on the intersection between the Gris and Scope Box and eyeball it by zooming in its not going to be 100% precise.
The only alternative I can think of is you Create a New Scope Box use Reference Planes and Assign them to then Box then Unassign to cut them down
You can then use Model Lines > Pick Line > Click on Reference Planes and not you have reference points to move and position the Box & Model Lines (select them All)
You also get additional snap points
I am sure there is possible an easier way through the View and Crop Region or an Addin?
Jay Colcombe
Message 10 of 29
Yes you can. Use rotate tool, drag the base point into an edge of the element, then you can rotate to align with the element.
Message 11 of 29
bryan_mentzel
Go to original plan view where Scope Box 1 was placed.  Go to plan view Properties box and set Scope Box to None.   Select Scope Box 1 in plan view and say you want to rotate it 5 degrees counter-clock-wise (CCW).  Start the rotation, then rotate the Scope Box clock-wise (CW) and accept.  Yes, you are rotating it (opposite direction) bass ackwards of what you might think.   Also, Revit automatically gets rid of Scope Box 1 and creates a new Scope Box 2 on the rotation.   Enjoy.   Also, see link https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-7783971E-9DEC-4BEF-BB57-A992C94745C4
Message 12 of 29
khalid.ansari7A9T6
Thanks @ToanDN  Doing that will not be 100% aligned with Eliment. bcoz you can not pick the exact corner of the scope box.
Message 13 of 29
The orientation will be exact. I didn't know you needed to align the edges.
Message 14 of 29
khalid.ansari7A9T6
Please read @jay_colcombe reply, you will get it
Message 15 of 29
Not sure what I need to get. I rotate scope boxes to align with angled walls constantly and the rotations are dead on correct.
Message 16 of 29
khalid.ansari7A9T6
Okay, I will try to explain one more time lets see if I am able to make you understand or not 🙂 If not my bad.
Suppose you have a scope box on an angle, and now you want to rotate that same scope box to align with some other element which is on a different angle, how will you do that?
Message 17 of 29
khalid.ansari7A9T6
@ToanDN
Message 18 of 29
khalid.ansari7A9T6
@bryan_mentzel
Thanks for your response, But my question is not about simple rotation of the scope box. Please have a look again.
Message 19 of 29
khalid.ansari7A9T6
Thanks @ jay_colcombe, I will explore your answer and let you know if it is a right solution. really appreciate your effort 🙂
Message 20 of 29
Delete that rotated scope box. Create a new scope box not rotated. Then use my method to rotate it aligning with the angle of the element.
