Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to make a cut (recess) in Precast stair
3 REPLIES 3
shuaib009
770 Views, 3 Replies
How I can make a cut in Precast stair for corbel in below highlighted locations?
There in no option of void cut Model in place etc. !!!
Below is the section for clarity.
Precast Panels are not shown in 3D image
3 REPLIES 3
RDAOU
in reply to: shuaib009
@shuaib009
  • Model it in-place as a family - use extrusions (then you can cut it with a void)
  • You can use dynamo to convert it to a Generic Model and cut it
  • Or you can simply leave it as it is and model the recess/anchor/corbel as a detail component which you can insert in the section view
shuaib009
can I convert only that  2 landings to generic model? I do not know much about dynamo.
Is  there any other solution?
RDAOU
@shuaib009
Then your easiest but not the most perfect option would then be to model stairs without the landing...then model the landings as floors which can be cut by a void
Forma Design Contest
