How to get rebar shape handle reference for dimensions using API
aleksandr_nekrasov7ZPGJ
When creating dimension in UI it conveniently suggests to select `shape handles`, displayed in status bar:
These handles include:
* Bar Plane
* Out Of Plane Extent
* End of Bar
* Start of Bar
I compared manually created reference with the references returned from the `get_Geometry` call - manually created reference is similar to a reference for one of the lines but without `LINEAR` suffix and has reference type NONE.
Is it possible to get the same reference using API?
navya_gelli
Hi @aleksandr_nekrasov7ZPGJ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Navya | Community Manager
Haven't found the solution yet - there is simply no API to do that. Here are some other examples from UI that I would like to be able to add via API:
aleksandr_nekrasov7ZPGJ_1-1777530393608.pngaleksandr_nekrasov7ZPGJ_2-1777530441119.png
