Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to extend roof rafters to roof ridge
4 REPLIES 4
rclement
699 Views, 4 Replies
ok I got roof rafters in. wooo hooo. now how do I extend these rafters to the roof ridge?
4 REPLIES 4
Viveka_CD
in reply to: rclement
Hi @rclement
Which version of Revit are you using?
Did you try the roof framing extension?
rclement
in reply to: Viveka_CD
im using revit 2018 school edition I have the extension but wanted to know how to do without it
Viveka_CD
@rclement
You can model a roof based generic family and host it to the roof.
bjur
Use out of the box dimensional lumber families to model the rafters. No in-place families needed. Set bottom of roof ply as the current workplane prior to modeling the rafters. Then connect the Blue grips of each rafter in any view and the joists should miter. You can always extend the rafters and cut with another work plane if needed.
