How to downloading Revit 2022 updates
bonaventure.ngwu.200175
Message 1 of 12
Hello guys, I loooking for a way I can download Revit 2022.1. I tried using custom download and I got a Revit 2022 viewer which is not what I want. The reason I need Revit 2022.1 is because of a CSIXRevit 2022.1 addin which can only work with Revit 2022.1 version. Currently I am using Revit 2022.0 and Revit 2023.
In summary I need to know how I can either download a Revit and a corresponding CSIXRevit.
Below is a screenshort of the continued message I receive while trying to export to Etabs
Replies (11)
Message 2 of 12
Ahmed_M_Heteba
You can download Autodesk Revit 2022 updates from Autodesk Accounts or download and install automatically from the Autodesk Desktop Application.
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/CloudHelp/cloudhelp/2021/ENU/Revit...
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 12
A_MAQ
Autodesk Desktop Application. quicker way
Autodesk Expert Elite
Message 4 of 12
Please, I am talking about Revit 2022.1
Message 5 of 12
Ahmed_M_Heteba
yes it's the same way either you use autodesk desktop app or log into your account and update
Message 6 of 12
MOR-ConorMacken
According to Autodesk, you need v2022.1 update installed first before you can apply the 2022.1.4, 2022.1.5, 2022.1.6 & 2022.1.7 hotfixes.
But you can't download the 2022.1 update anymore (or any update except the v2022.1.7 hotfix), so if you're stuck on v2022.0.x like I am, the only thing you can do is download a full fresh installer which appears to have v2022.1.7 hotfix built in based on the filename.  I'm downloading it as I type this.
This is the last Revit version on the list I see in my download page, so it will probably disappear when v2026 arrives next year.
Message 7 of 12
CatherineBourdeau
Hi, I'm also looking to download version 2022.1.8, but I can't find it anywhere...
Could you please send me your download file?
Thanks!
Message 8 of 12
will_young
Hi, you can download via the Autodesk assistant as below:
Message 9 of 12
CatherineBourdeau
Thank you!!!
Message 10 of 12
CatherineBourdeau
Hello!
Thanks again for your response. I downloaded the installation file for Revit 2022 from the location you indicated. However, when I run the installation, it's version 2022.0 that gets installed, not the updated version (2022.1.8).
Do you have the installation file for the update?
Message 11 of 12
kjscheer
I am running into the same issue, the only installer available installs 2022.0 and the update doesn't show up on Autodesk Access.
Message 12 of 12
Thanos603
The Revit 2022.1 update is available from https://up.autodesk.com/2022/RVT/F049ACC2-8F1C-38C2-8CC9-9C39672807B1/Revit_2022_1.exe and the latest update, 2022.1.8, is available from https://up.autodesk.com/NetSWCOM/prd/2022/RVT/CFAEE3C8-36F0-3DF4-964A-185EB42271F5/Revit_2022_1_8.ex....  These two downloads should allow you to update Revit 2022 to the latest available version.
Anthony Michniewicz
Principal QA Analyst
