How to create stairs in Revit Structure?
Message 1 of 10
Not sure if this is a dumb question or not, but, how do I create stairs in Revit Structure (2014)? I've seen several tutorials that use the Architecture ribbon tab and from there go to a component creation dialog. And on those tutorials they have both the Architecture and Structure tabs. But I can't seem to find this Architecture tab on my ribbon. I just have Structure, Insert, Annotate, Analyze, Massing, Collaborate, View, Manage and Modify.
Is there a way to turn this Architecture tab on and off?
If the Architecture tab doesn't exist on Revit Structure, how to do you create stairs then? All I really need is a stairs material takeoff, not really looking to do any analysis on them.
Replies (9)
Message 2 of 10
gregamhale
There are several different versions of Revit. The three that you are used to are the three disciplinary versions for Architecture, Structure, and MEP. There is also product simply called Revit. This version includes all three disciplines and is sold as part of a product suite that includes things like AutoCAD, Navisworks, and 3Ds Max Design.
I don't believe Revit Structure comes with the stair tools. It is a Revit Architecture feature.
Message 3 of 10
If you use Revit 2014 Premium Product then you will get Revit Architecture, Structure & MEP (System) all in one. In Architecture Ribbon you will get "Stair" option to create a stair. Please find the attahced image file for your better understanding what i want to say.
Thanks & regards,
Subhradeep Sen
kolkata
India
Message 4 of 10
um wierd, we use Structure 2014, i can see the Arch tab just fine. (although if they moved the stair feature elsewhere i wouldn't need that tab at all!) and Yes, you can modify the UI slightly, we have added custom ribbons, but i don't know about taking out the default ones.
Message 5 of 10
Try looking in the Application Button (Big R in the upper left hand corner).  Then go to Options -> User Interface and make sure the Architecture Tab is selected to be on.
Message 6 of 10
That´s it... I hadn't enabled the architecture tab in the Revit options. Thanks!
Message 7 of 10
curious stgauss, what version are you using? (upper right question mark), about) as I don't see this as an option. (Im using Structure 2014 update 2)
Message 8 of 10
I'm on Revit 2014, build 20130308_1515, 64 bits.
Message 9 of 10
ahhh hence my confusion, those options only exist in the all-in-one Revit, and not in the discipline specific versions (Structure, MEP, Arch).
Message 10 of 10
Dear Misters
As long as I know Revit structure Tag do not have Stair Category. So we only have to creat in Archi Tag right? and after that make a component in situ by floor category we make a stair and delete Archi stiar and we got Structural stair , right? or is that method idk 🙂
