How to create opening through a curve beam?
wickedzik
wickedzik
How to create opening of a curve beam?
By using Opening - By face, I can make it with a straight beam but not possible with a curve beam.
Any method?
Thanks.
RPTHOMAS108
You can create a face based family containing a void.
In the family environment cut the solid that represents the host with the void then load into project and host on the face you want to cut:
When you use other family templates containing voids and either version of 'cuts with voids when loaded' then that doesn't seem to work for this case (not even with cut tool in project). So I just stick to the method I outlined initially.
ennujozlagam
you can try this?
https://www.youtube.com/watch?v=deBWWYFX3hE
wickedzik
Hi Ennu, sorry but this can't be applied in curve beams which is my problem until now.
wickedzik
Thank you so much RPTHOMAS. This actually worked.
