How to connect the beam to the column without gaps
Caed9
Caed9
Hi, Revit community,
Is there a way to remove the gap between the foundation beam and the foundation column?
I already tried looking on the properties palette to see if there was an option, but all I see is y and z justifications.
I just want to remove the gap, could you please give me some advice on how to adjust it, I also tried changing the material on the beam to match the column, but the gap was still there. And when I tried to join them  I get a message that says that they are already joined.
Thank you
catalin_lang
Select the beam
In the Properties palette, change the Start/End Join Cutback to 0.00. By default it's 1/2 an inch
catalin.lang
_Vijay
If its concrete use Beam /Column Tool to join.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Caed9
thanks catalin.lang I swear I searched for that option in the properties pallette but I could not find it. Now that you tell me, they suddenly appeared. Many thanks for your Advice I really appreciate it.
Now I'm wondering when are those annoying gaps useful?
