How to change the height of only the later step
ball_wu
ball_wu
Hi everyone!
I’m a revit newbie.I’m facing a problem.I want to change the height of only the last step,but i don’t know how to do it.
Could you please help me? Thank!!!
jay_colcombe
Stairs are controlled by the Levels and then provides you with the number of steps to reach that level
In Plan > Select Stairs > Edit Stair > Drag Circle Node to add an extra step
Jay Colcombe
Autodesk Certified Instructor
ball_wu
Thank you for you reply!
I'll try following your steps, but i not find circle node.
Ahmed_Muharram
Revit doesn't allow to change individual riser height
you can work it around through either changing the top level of the stair or to put additional floor on top of last riser
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
ball_wu
Thank you of you suggestion.
jay_colcombe
You do have the option to manipulate the Heights and Step numbers but as @Ahmed_Muharram states you cannot edit the height of an individual step and you could add another stair with only one step with offset from levels to achieve this?
Also there is a hidden option in the Run System Family for you to End with/without a riser which often can help.
Jay Colcombe
