How to change scroll speed
zachnTES
zachnTES
I just upgraded from Revit LT 2020 to Revit Structures 2023. On the LT 2020 version, when scrolling though windows (such as components, filled region options, windows/doors, etc.) it would scroll less than one full window. This was great because I could always find what I was looking for. Now, with just having upgraded to the 2023 version, with no other changes, all my windows scroll 2x the full window length. I cannot find in the settings where to change this.
MichaelDol
maybe you should do it through the system mouse settings.
Mikhail Dolgikh / Михаил Долгих
BIM-Manager & Teacher / БИМ-Менеджер - Учитель
Facebook
zachnTES
That would change my default scroll speed. I don't want to do that because that hasn't changed. The only thing that has changed is within Revit itself.
jasoncolcombe
Unfortunately there is no such specific setting in Revit directly and this is more Laptop/Peripheral device driven.
If you think there is an issue I would consider reviweing the mouse settings where some have trouble shooting process that are found in Mouse Properties via Control Panel. The Microsoft mice have a wheel "tab" that offers an "advanced" button where you include Revit.exe in a list of apps to let control the wheel function instead of Windows imposing it's settings on the mouse.
Or there could be some speficic software from the mouse manufacturer which you can install which contains application driven settings.  I use a Logitech mouse and this has such an offering.
As a final option you now have the option to search in the Properties Palette which is again another workaround but may help in the short term?  Or use the Up/Down arrows on your keyboard
I hope you get to the bottom of this and keep me updated
