how to annotate truss layouts traditional way in revit ?
gideon
gideon
i know for joists we can use beam systems to draw joists in floor effectively.
but for trusses, i think there is no similar commands even in revit 2020,
my questions is how to model jack trusses and common trusses and labels them in the traditional way like the picture attached
ennujozlagam
you can refer <<here>> and see if helps. thanks
RDAOU
@gideon
  • Annotate the slab using Span Direction Symbols... If none is loaded into the model, it should be available in the OOTB content Library
  • You can edit the family after placing it and Add a LABEL
  • The Label may use any of the OOTB parameters available for Floor Elements, OR you can use
