how do you create 'L' shape bolt pattern?
jeremyJGF5Z
jeremyJGF5Z
How do you create a 'L' shape bolt pattern?  I can't figure out how to have a bolt pattern on an L shape plate using only 3 bolts.   It's either 2 or 4 bolts.  Is there a way to eliminate one?
I'm using Revit and Advance Steel.  Can't figure it out in either program.
jeremyJGF5Z
Nevermind... figured it out.  It's 2 different linear patterns next to each other.
ArmanMargaryan
Would you please post a screenshot?
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
khiem.tt
You can try tab Steel/Anchors, Standard: Russian. I dont know how to create 3 botls in 1 set, but you can create 2 set: fisrt set 1 bolt, second set 2 bolts
YarUnderoaker
Only in Russia bolts has L shape 😆
