How can I create a box truss family?
VladislavkR5Z6S
Message 1 of 8
VladislavkR5Z6S
I need create box truss family.
I don't know how do it.
Replies (7)
Message 2 of 8
L.Maas
A standard truss family will not help. I would look if you could create something out of a beam family.
Other option might be to create a box truss out of multiple (truss) families.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
VladislavkR5Z6S
I tried to create a farm based on the Metric Structural Framing - Complex and Trusses family of templates.
but it is not possible to set profiles for chords, diagonals and struts.
probably something I'm doing wrong
Message 4 of 8
hmunsell
something like this?  i didn't know what version you have so this is in 2017 format. i initially created it as a Generic Model then changed the category to Structural Framing. Feel free to reverse engineer it as needed 🙂
Howard Munsell
Message 5 of 8
VladislavkR5Z6S
Yes, this is very similar, thanks a lot for the help, now I'll look at the file
Message 6 of 8
hmunsell
that one is made as a 2'x2'x4' base unit. then it was grouped and arrayed. the array is using a parameter "Truss Length" to set the number of arrays using a formula. setting the truss length will adjust the array in 4 increments.
Howard Munsell
Message 7 of 8
Amin.ShahkaramEC69Z
is there a way to use true structural members instead of direct modeling with extrude ? Specifically looking to do this with adaptive families though!
Message 8 of 8
hmunsell
you might be able to... I've honestly never tried :-).  You can bring other Structural Framing elements into Structural Framing families, so id think you may be able to.
Howard Munsell
