Hello Everone
Please I need advice I have a grade slab plan, the slab is an edge slab, but I don't need to show the slab edge on the plan only the slab without edge, I have tried with a range of widths but not getting any good results.
Attached is the plan for clarification
Solved by EdwinG. Go to Solution.
do you need to see anythign else below the slab? if not, set your Show Hidden Line to None.
Howard Munsell
Do you want the show Hidden lines for other things? If no, then change view discipline to Coordination and set hidden lines to by discipline. If yes, then change the view range bottom and depth to be above the slab edge elevation.
