Hidden Lines Issue
Hidden Lines Issue
chris_curley2
Hidden Lines Issue
chris_curley2
Hi All,
Revit 2023
I am experiencing a problem where hidden lines will not display consistently.
I have ruled all the obvious out, discipline, view range, etc.
This is what the display looks like on opening and after display area change (like changing the display to a different area and refocusing back to the same location)
This is what it looks like after I change any of the following:
scope box, view range (slight change only to the view depth and reverting to the original view depth yields the same results)
After the display area is changed and I refocus on the area the lines revert to being displayed as in the first image.
Notes:
  • When an object is selected in the view in either circumstance it displays as hidden.
  • This is pretty much consistent behavior across the whole plan area
  • On some of my other plans within the same model the problem does not exist (for this reason I'd be reasonably satisfied it's not a graphics card issue)
  • Exports (dwfx) do not have this issue, ie. the hidden lines appear as expected.
Appreciate any feedback.
Chris
EdwinG
it is a known issue in 2023 as far as i know it's solved in 2024
https://forums.autodesk.com/t5/revit-structure-forum/hidden-lines-incorrectly-displaying/m-p/1175006...
chris_curley2
Thank you
peticid
Hi Chris,
Today, Revit 2023.1.2 has been released and it also includes a couple of fixes related to hidden lines. Please install this latest update and  see how the views are displayed. If the problem still persists, please share the files with me on this thread or send me a private message.
Here you can read more about this latest update.
Dan Peticila, M.Sc. Str. Eng.
Product Manager | Autodesk Revit
chris_curley2
Dan,
This does have appeared to have solved the issue.
Chris
peticid
Happy to hear this. Thank you for sharing your feedback, Chris.
Kind regards,
