help with merging 2 plates
filipedultra
filipedultra
 guys, i need to connect these 2 metal plates together as to make it one single piece.
there used to be a tool in revit that did this by selecting the 2 faces of the objects you wanted to merge and it would add the finish in a arc. i cant seem to find this tool anymore..
Are they two parts in one family or two families altogether?
filipedultra
Theyre 2 metal plates created separately. one on top of the other
If it is just for visualization then create an in place sweep, use pick path to pick around the tube, draw a fillet weld profile to create it.  It has no welding properties or other structural value though.
filipedultra
It’s not really just for visualization. It’s supposed to be just 1 piece. The command I was referring to was the fillet command. I can’t find a way to apply to those metal plates tho.
filipedultra
Ive tried using that tool but it just applies 2 lines to the visual. Not really what I was looking for. Maybe I’m doing it wrong.. can you post a video showing me how to do it?
