02:05 AM
As you can see in the image, i have a wall that changes in size over a specific length.
The reinforcements in this wall (hairpins) will therefore change over the length over the wall, getting less tall when the wall is also getting less tall.
So far, the only way that i found to do this, is set it to a layout "single" (copy the c.t.c distance again) reinforcement bars and setting the height.....
Is there no way to set ctc distance with number (layout: number and spacing) and let it automaticly grade with the wall? so the hairpin heights change to fit the wall ?
Link copied
