[HELP/BUG?] Beam justification shifts after using steel connection tools - REVIT 2024
Discipline : Structural Steel
Issue
When modeling a steel beam (example: HEA 300), the justification is correctly set:
Z Justification = Top
Y Justification = Origin
After using steel connection tools (cut at flange, shorten, cope, etc.), the beam representation no longer matches the justification values:
The beam looks as if it were set to Z = Origin and Y = Left/Right, even though the parameters still show Z = Top, Y = Origin.
Steps to reproduce
Create a steel beam with justification Z = Top and Y = Origin.
Apply any steel connection tool (cope, cut, shorten).
Notice that the graphical representation of the beam shifts, ignoring the set justification.
Expected behavior
The beam should keep the justification defined in its properties, even after applying steel detailing tools.
Questions to the community
Has anyone else experienced this behavior?
Is this a known limitation/bug of Revit steel detailing tools?
Do you know any workaround to reset or force back the correct justification without deleting/recreating the element?
Example
(see screenshot attached – justification set to Z=Top, Y=Origin, but representation shifted).
Thanks in advance for your feedback!
