Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Head Clearance Check
2 REPLIES 2
francfiles
558 Views, 2 Replies
We have this multi-story building with 2 level parkade. We want to be able to check head clearance between parkade and the floor above. The thing is, the floor above and the parkade directly below it, slopes in all direction. so instead of checking them 1 by 1, is there a way for Revit to do the checking? Can Revit make sure nothing goes below the minimum required head clearance?
2 REPLIES 2
in reply to: francfiles
Temporary copy the lower floor up (or the upper floor down) the distance of your required clearance and run an Interference Check.
francfiles
in reply to: ToanDN
Sometimes I feel really stupid. Thank you. I will try that idea.
