halftone issue
halftone issue
halftone issue
Please see attached image.
I have capping beam elevation where I want capping beams to standout. Whenever I halftone floor (which sits on capping beam) I get result shown in attached. Floor take priority than capping beam as in picture 1 bcz floor is on capping beam the top edge of capping beam which should appear darker gets hidden by floor halftone.
Is there any other way to fix this issue other than linework tool.
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @Anonymous,
Are you able to upload the model so we can take a look at the view? Please advise which view you are seeing this issue in, thanks!
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Pls find here right starting view. Refer view Retention Elevation RE6.
I made this as a starting view
Please check. Thanks
