08:55 AM
I built a frame at a column location which will occur at the majority of my column locations. I would like to group this frame system and copy or array it so that when I have to make changes to the frame all of the frames will change automatically. However when I select all of the elements for the fgroup and select the group command I get the following error. "A structural element will be detached from grid(s) due to inconsistent group membership." how do I remedy this problem? We are in the beginning stages of the project so we are using preliminary column, beam and bracing sizes and I would like to be able to change them all at once as the project design progresses.
