GRAPHICAL COLUMN SCHEDULE
lucia.lapusneanu
lucia.lapusneanu
Hi, in Graphical Column Schedule the list of the column apears as an evevation. I need this kind of schedule but to apear as floorplan view, and also later to divide in schedule by floor. I mean a list of all columns of firts floor to apear in floorplan, second floor and so on. I was thinking to make like in revit architecture a simple schedule and to put image or a callout, but this will be much work because is a very big building and have many column. I hope is easy to understand my quetion. Have somebody had this necesity, what is the best way? Thank you in advance.
jay_colc
You can filter Schedules by Levels so this is feasible.
As regards an image of the Column Shape in Plan you would need to add an image to the Family and then call this out this out in a Standard Schedule but not in a Column Schedule unfortunately.
You can however Annotate directly into the Graphical Column Schedule using the Annotate/Tag Tools and callout any Parameter Information such as Section or Column Reference
Help | Tag columns in a graphical column schedule | Autodesk
Jay Colcombe
Autodesk Certified Instructor
