Generic annotation family nested in structural framing model family not showing up
semi
Message 1 of 18
semi
Hi everyone,
I'm trying to combine a 2D detail annotation into a 3D model family but the problem is that my 2D text indication always seems to vanish when I load it into my project.
For example:
This is a generic annotation loaded into a structural framing family.
It has visibility parameters and all for certain purposes of detailing but they never appear when loaded.
Replies (17)
Message 2 of 18
jay_colc
Is the Family/Annotation set as Shared within the Family?
As its Structural In discipline this could also relate to
Nested annotation in a generic model disappears in floor plans when turning on the "Structural Frami...
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 18
semi
no, because Revit does not allow shared detail parameters into 3D model families
Message 4 of 18
It only works in plan view.
It is not a great idea to embed annotations in a model family since they will show (when they do) everywhere, every scale, and turning them off is a pain.
Use tags instead.
Message 5 of 18
semi
Well, they are all based on instance parameter visibility settings so that would be fine (if it worked)
Message 6 of 18
No they are not fine. Instance visibility parameters are controlling NOT per view, but globally.
Message 7 of 18
semi
What are you talking about?
It's instance, not type.
See example:
Same detail - Different views and other parameters checked on or off.
Next example : Same beam, one was given 2 stiffeners checks, the other none:
in this last example I checked another one for the same beam
Now if this would also work to bring in text annotations I could make my details soo much faster.
Now I always have to copy my detail annotations ON my 3D model details.
It would be much safer and faster to just utilise my annotations in the 3D model objects.
Message 8 of 18
You turn one instance off via a parameter, it is off in every view. Got it?
Message 9 of 18
semi
ofcourse, every detail is different
Sometimes the floor bears onto the left side of the beam, sometimes right or both and we need to adjust every detail to every situation. This is what we want.
Sometimes a beam gets connected on the left side and the perpendicular beam needs stiffeners in that situation.
Thats why I need all those parameters to adjust them to every situation.
All I need now is text with it.
Message 10 of 18
semi
This is an example of some details per beam. These are all details with visibility parameters on or off and as you can see they are not all the same per view because they are instance parameters, not type.
Message 11 of 18
Do you show the same annotation on site plan, plan, detail, which have different scales altogether?  Tell me how you turn off the annotation for one beam in one view and leave it on for another view.
Message 12 of 18
semi
(view in My Videos)
See attached video. Do know this is an example with a detail component copied on top of a structural framing model.
What I want to achieve is that same detail component model INSIDE the 3D model family.
So far this only worked for the looks, but it does not work for the text annotations.
Message 13 of 18
semi
considering the scale, it does exactly as it supposed to do: the text size stays the same
(view in My Videos)
Message 14 of 18
Isn't a sheet with smaller scale views (1:200 for instance) swamped with a bunch of annotations that you can't turn off and they covering other model elements?
Message 15 of 18
semi
Why would I need a plan with scale 1:200? I work for structural engineers making reinforcement details
Message 16 of 18
Revit is a universal software serving a variety of audience, not only structural detailers who expecting a Revit family would work the same as an AutoCAD block with attributes.
Message 17 of 18
semi
Is that the reason why generic annotations are not visible in 3D model detail families which was my initial question?
Is it because Revit is a universal software serving a variety of audience, not only structural detailers?
Well at least we have Revit dark mode now, because we were all waiting for that...
Message 18 of 18
semi
We've just encountered a serious problem with a project where all the rebar detailing was modelled and annotated.
Now the architect just decided to adjust a level with 10cm. And now all our details are all messed up.
It would again be very helpfull if generic annotations could be included inside a model family, so these would also adjust to the changed level.
