Gaps between panels while converting the physical model to analytical
karthikb200106
karthikb200106
  1. While trying to convert the physical model of walls to analytical model through analytical automation i am getting the gaps between the panels.why is this happening?h
jay_colcombe
This is caused by how Revit joins walls together automatically, and has been dramatically improved in 2025 to overcome this.
you can either;
  • Mitre the wall joints
  • Edit the tolerances in the Analytical Model Creation to overcome this
Jay Colcombe
Autodesk Certified Instructor
karthikb200106
Exactly how much tolerance should i keep to join the walls. I tried with
different values but it didn't work.
Thank you for the reply.
jay_colcombe
I cannot repeat as i am using 2025 but i recall I had to use 500 (as i was in "mm") to bet beams to adjust to floor levels.
I also ensure the Walls for the Primary/First Elements to be adjusted
Please review the following for additional guidance;
Help | Physical to Analytical Automation | Autodesk
Jay Colcombe
karthikb200106
Have any other fixes? because I am currently using Revit 2024. I can't use Revit 25 version.
Whatever the tolerance I insert, the walls are not joining for analytical but its working good with remaining members like beams or columns.
