from revit to cad exporting of structural columns as block in cad
4ukunam
4ukunam
Community Visitor
Community Visitor
how to export from structural column in revit to autocad blocks in 2d format
ennujozlagam
you can export in 3D view mode your columns by tick ACIS solid and it will become solid in autocad?
hmunsell
if you want then in 2D format, use the Export to DWG option (File > Export > CAF Formats > DWG) and select a Plan View from the list.
  • If you select a Plan View, everything should export in 2D.
  • If you pick a 3D view, everything will export in 3D.
Howard Munsell
eli.fligelman
Hi @4ukunam
When you have your view open in Revit, whether this is a plan view or section view, go to:
File->Export->CAD Formats->DWG
Save the view as a DWG file.
In AutoCAD, load it as a Xref to your project or to a Block editor.
Eli.
handjonathan
Hi @4ukunam
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @eli.fligelman @hmunsell @ennujozlagam helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
