Foundation Slab visibility...help
In the foundation plan of my model I've drawn in my floor using the "Structural Foundation: Slab" feature, mostly so that it shows up in the model details I'm creating. Since I have no reason for the slab to show up in my foundation plan view, I'd like to hide the visibility of the foundation slab only so that I can easily see/tag the foundation walls and footings below.
The only way I've been able to turn off the foundation slab visibility is to uncheck the "Structural Foundations" box in visibility/graphics, but this hides the footings and foundation walls as well. Changing the view range is not an option due to the fact that my top-of-slab elevation is equal to my top-of-foundation-wall elevation.
Help!
apjones
You could make the floor slab transparent.  Would that solve your issue?
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
