Foundation Details.
Foundation Details.
markkibui101
Foundation Details.
markkibui101
I find that most of the projects that I do have similar foundation details. Is there a way to automate this process to save time?
For instance; having detail elements, like insulation, Ground surface, hardcore hatch, e.t.c. I have attached an image to explain what I mean.
L.Maas
I am not sure what you want to automate.
You can create drafting view(s) with your details. Put it in your template or in a separate project where you can copy them from when needed. You also can use detail item families where needed (see the Autodesk Libraries for examples)
And you can create all kinds of hatchings for your needs (in your template)
Louis
Please mention Revit version, especially when uploading Revit files.
markkibui101
Thanks you.
