Formwork for foundations and other elements
elias_munoz_neyra
elias_munoz_neyra
Greetings,
I0m am currently working on a university assignment and I'm to calculate the formwork for the foundations and foundation beams SOFiSTiK BiMTOOLS 2016 (64-Bit) and calculated it, but it finds the whole surface of the element, still counting the surfaces in contact of the adjacent elements (highlighted in green), which I don't want to find. Is there any other  tool or a way to do so?
Thanks in advance!
I had the same problem with Bimtools 2014. Try to join connected elements but i dont think that this is going to fix the problem.
I have not understand Sofistik approach to this issue.
elias_munoz_neyra
Thanks for your reply.
I just did that a couple of days ago, but it still counted the whole surface, as if it didn't have any contact with other elements. SO I just made generic models on the surfaces as if they were actual formwork. I could beacuse it is a small project, but I still wonder if you can do that with an app or program it in some way.
