Floor reinforcement layers
ArmanMargaryan
ArmanMargaryan
How can I modify floor reinforcement layers without using the Remove are reinforcement tool?ScreenShot 115.png
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
jay_colc
If you need to edit the arrangements (bar size/spacings/etc.) you need to edit the Area Reinforcement Configuration by Tab Selecting until you find the Area Reinforcement and editing this way.
If you have to manual edit you could try tabbing and selecting the layers to see what options are available from the contextual tab these may be suitable for your needs
Otherwise the only option is to remove the reinforcement from the area itself.
Jay Colcombe
Autodesk Certified Instructor
ArmanMargaryan
unfortunately it's too long and boring
Arman Margaryan
Linkedin | Facebook
ArmanMargaryan
I created a new idea
https://forums.autodesk.com/t5/revit-ideas/change-the-order-of-area-reinforcement-layers/idi-p/12390...
Arman Margaryan
Linkedin | Facebook
jay_colc
Agreed, there are plenty of Third Party Apps which deal with this better.
I personally copy and paste aligned to same place and create my layers this way and treat them individually.
Jay Colcombe
