Floor blocking underlay
semi
semi
Does anyone know why my floor is blocking my underlay?
I'm on Floor +V01 looking up to the ceiling towards +V02
When adding a floor between +V01 and +V02 it will block my walls lying above.
view without floor:
View after drawing floor:
Section setup showing between +V02 and +V03:
Cut view is below the selected floor, looking up towards that floor.
What is the floor elevation? Play with the view range top relative to that value.
semi
my floor is lying just underneath the floor level I'm looking to:
I'm standing on V01 looking down starting from cut view 100.
When I use V02 as an underlay it shows this floor but not the walls above that floor.
The walls only show when I delete the floor.
