Flip Rebar direction
-FDC-
Advisor Advisor
-FDC-
Is it possible to "flip" the rebar direction ?
For example:
I draw a rebar (the sloped one) which has a length of 8856.12.
I want to give this rebar a clean length of 8800.
If I do that sometimes (a lot of the times) the wrong side is shortened.
In this case the right hand side should be locked and the left hand side should be used to shorten the bar.
I know I can do it with constraints but it would be nice and a lot faster (in a lot of occasions) if I could flip the bar or lock it at one end.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
No flip feature that I'm aware of. I didn't test, but does Align help out in this situation?
Otherwise, this could be a good enhancement recommendation to post to Revit Ideas
Martin Stewart
AEC Support Specialist
